Since yesterday, any cuts that I make on Thick PG clear acrylic are not completely finishing, leaving a small burr (that’s fairly sharp on the finger, I might add).
For example, I am trying to finish up a run of round awards made from thick clear acrylic and when it cuts out the circle, there’s always a burr left in the same place on each item (pretty much straight at 9:00 on the circle where the cut finishes).
This has happened on the last 3-4 consecutively that I have cut in the last day or two.
The items I cut out of walnut PG cut smoothly and completely during the same time period.
Ooh, good idea. I need to give it some thorough cleaning anyway, so that won’t be a bad thing. I’ll check around here for tips for good cleaning practices.
