Hi! I have searched the forums and have seen a lot of posts started about Kraft Tex and that people were going to play with it but I have yet to find some actual advice on using it
Does anyone have suggested engraving and cutting settings for it? Thank you!
It’s made from paper and latex so it should cut just fine. Your best bet is to run a test. This one takes up a tiny bit of material:
I made a fake wallet with it once. My cut settings were speed 450, power 80. Score settings were speed 250, power 2. I didn’t really spend a lot of time optimizing so these could probably be improved. I didn’t try engraving.
Has anyone tried engraving? I’ve run a couple tests and it’s coming out a bit odd. Any ideas where to start on settings?
Here’s a quick test that will let you narrow down to a smaller range very quickly:
