Hi everyone! I’m looking to cut specific shapes out of a roll of 3M Bumpon. Does anyone know what settings would be best used to cut out of this material? Here are the details:
Thickness: 0.8 mm
Material: Natural Rubber (R30) and has adhesive backing made from polyurethane
Thanks everyone!
Check out #6 for an ironclad cut test method:
Hello! You’ve been referred to this post because you have a common problem or question. Check out the list below to see what this post can do for you. Just click on a topic that interests you.
1: I'm new to Glowforge and really have no idea where to start Hey, welcome to the forum!
Glowforge has a getting started page, it’s definitely worth your time:
<a href="https://support.glowforge.com/hc/en-us/sections/11792517736475-Design-and-Print-Tutorials">https://support.glowf…
Searching for rubber settings might get you narrowed down so that you can find your perfect settings with @evansd2 method that much faster!
https://community.glowforge.com/search?q=rubber%20settings
AFAIK you’re the first to try Bumpon, so do post your results when you find them!
This might be a good starting point!
I need a rubber stamp with my name and title on it to help speed some documentation at work. I picked up a sheet of “low odor” rubber from Johnson Plastics and got to work. The item number is RUS001 if anyone is interested.
The first thing I learned was that “low odor” is a subjective term. VERY subjective. Other than that, the material itself was good and consistent. I did an “R” (and then flipped it horizontally) to test it on inkscape, and it was pretty easy. I used two different color…
