Hi there. Has anyone come across whether you can engrave a hockey puck on the Glowforge, and if so what possible settings would you use? Thanks ![]()
This has been discussed - recently. Also settings for non Proofgrade materials can only be discussed in the Beyond the Manual section.
I googled this subject a week or so ago because someone else asked that same question. I came to the conclusion you can. You will have to remove the crumb tray and prop them up to the correct height of course. I assume you know that procedure.
Thank you. New to posting here appreciate the redirection!
What settings did you end up using for engraving a hockey puck?
Welcome to the forum.
Settings for non Proofgrade materials can only be discussed in the Beyond the Manual section of the forum. Perhaps you could send a direct message to the person that you think successfully engraved hockey pucks.
Hmmm. Iβll have to figure out where that is. This is the first time I commented ![]()
