I have a bunch of the Ikea cork coasters. What have you used for settings to engrave or score on these?
Your best bet is to test a bit because your desired result may be different than other users. That being said, I have had success with 1000/20/195
Not settings but I used those coasters in a project:
You’ll need to learn about using the Glowforge without the crumb tray if you haven’t already. They’re slightly thicker than 0.5”.
Wow those are so cool!
Thank you so much, I will try yours and see what happens. I would like to use them up and make some gifts.
