im trying to make some 5mm eva foam rubber gaskets for a car and need to know the settings
Xabbess
February 12, 2023, 5:12pm
Try using the search feature…there are lots of posts about eva.
It is also worthwhile to learn to test to get optimized settings for the specific material you are using. EVA can vary in thickness and density between manufacturers and even batches quite a bit.
Don’t know what settings to use on a material? The only way to be sure is to test. Good news! You can effectively test on a thin strip on the edge of your material, it’s fast and easy.
I use this shape to do so (SVG attached):
[Material_test]
Click here to download/save
Or click here for the ZIP: Material_test.zip (3.3 KB)
To use:
Set the first operation to score (the numbers). You’ll use these to identify your cut pieces later.
Set each of the curve shapes to a power/speed combo t…
system
Closed
March 14, 2023, 5:44pm
4
