shogun
August 11, 2020, 2:12am
By day, He is just a mild mannered 3 by 3 white cube…
But at night…
The innards are a paper liner (purple just happened to be what I grabbed), cut to an interesting screen pattern I got on Etsy.
Next time I want to avoid the glue marks on the cube, so I will likely go with a poster board inner cube and not glue to the sides at all if possible.
The electronics are two sets of flicker flame LEDs, half red and half yellow.
The base is walnut and maple, the soldering is sub par, the workbench appears to have been involved in a struggle and I, gentle reader, am not yet done putting lights in things. Oh no… not even a little.
MWAHAHAHAHAHA cough hack cough
As you were.
Nice and clean.
Cool! thanks for sharing the inspiration.
I just checked and I seem to have over 1663 patterns to try on a thing like that. I need to manage the light part better
Thats fun. I bet with the right spiral pattern in there and if you could get the lights to flash in sequence you could get some really interesting results.
Aloha
August 11, 2020, 6:01am
5
Oh! Awesome!!! Make it into an ambient orb like device!!! Those make me happy.
Nice! Love the mix of gf and electronics!
cynd11
August 11, 2020, 10:48am
9
Oooo, cool! I didn’t know you could get LEDs in that size that do a flicker pattern. Would you care to share your source?
Yup that is what I was thinking. Combining the filter pattern with that could be cool. Maybe a double layer screen with a slight gap for a more complicated shadow.
Counter rotating changeable cylinders?
Getting close to reinventing the moire explorer…
Since I was a kid I was fascinated by the moiré effect when two overlapping patterns create another pattern / image.
After getting my Glowforge, I had cut out some regular patterns of holes and slots etc, and noticed they would create that same kind of interference pattern when overlapped. So I figured it would be a fun exercise to create a gadget with interchangable discs to explore the moire effect. I call it the Moiré Explorer
The first prototype was a simple C-shaped ring with captured …
Except as rotating cylinders instead of a disk, and changing lights. There would be major differences as the related angles would not change so it would be more lava lamp. If the lights went up and the design went down it would be a problem for the easily hypnotised though.
Nice #necrogame though
Getting close to reinventing shadow projector toys, which I’m not sure anyone has posted a lasered one?
shogun
August 11, 2020, 2:48pm
15
I get them from Amazon:
https://www.amazon.com/gp/product/B077XDPXNT
Tons of cool colors.
cynd11
August 11, 2020, 3:04pm
16
Thanks! I have a project in mind for this…
shogun
August 11, 2020, 3:31pm
17
I really kind of want to stick one of these in a cube:
But I currently lack the patience to build one.
This makes me want to just sit and stare at the picture!
Led cubes like that are a heck of a soldering exercise. You’ll also learn about charlieplexing, it’s quite an undertaking.
That’s really neat! You could get some interesting effects depending on how you cut the inside paper.
