I am having a Hell of a time trying to find the perfect center / square on my Glowforge
I set the thickness, i used the focus tool, and my centers / squares keep shifting
here are two images, WHAT GLOWFORGE SAYS IS CENTERED.
Donât bother. make a corner/bottom edge jig. Youâll lose some overall size because of the margins of your material, but youâll get proper alignment. Judging by how small your left and right margins are, a side jig would probably work well for you too, with minimal size concession.
I did an edge jig and photographed it a while back:
Are you trying to find the center of your cutting board or the usable GF bed space?
If cutting board, @evansd2âs jig suggestion is the easiest and most reliable way.
yes @evansd2 has the secret sauce, as usual
I am doing a run of cutting boards, and they need to be burned from edge to edge (or as close as possible) I was able to suss this with my plus, but the pro has a âdifferentâ personality
(yes, I did an head alignment it was the first thing printed / done when I got the unit.)
You might be able to do some cleverness if size is paramount, @MyDogsThinkImCrazy has done a lot of work with marking the floor of the glowforge for no-tray ops â you might be able to squeak a little more engrave size out of it. In general I find that limiting factor is that the aspect ratio of the engrave or the board doesnât match the aspect ratio of the cutting/engraving area, so the gains are pretty small as a rule.
In your case, the art aspect ratio seems to not quite match either your board or the working area (itâs close but maybe not exactly) so your margins arenât going to be dead perfectly balanced anyway⌠so size and whatnot are entirely up to you as artistic decisions.
I find that the least forgiving alignments/margins are circular, itâs noticeable if you are off on positioning by even a little bit with a circular engrave on a circular material. With things like this board, itâs not as demanding.
Anyway, judging by the aspect ratio of your art I suspect that youâve maxxed the vertical size more than horizontal size, so I think it looks like you wonât need to concede any engrave size by shifting it to the right or left as with an edge jig. Then, the issue will be engravable area at whatever speed youâre using. If youâre doing high speed, an edge jig might push you too far to a side and youâll run into limits there. If that happens, reduce your speed and you might be back in business.
Old school â lay a straight-edge diagonally from corner to corner and lightly pencil in lines that extend about an inch in from each corner (just dark enough to be seen, or underlay a small piece of masking first). Repeat for the other 2 corners. Nudge your design so that the four corner anchors intersect the pencil lines.
Easier and faster than a jig for one-offs or small production runs, IMO.
Keep in mind youâre not seeing the entirety of the cutting board in this imageâŚother than the bottom image looking larger theyâre placed on the tape identically.
