So, I’m having a slight problem with a few files I’m trying to import into the glowforge app… it looks like, upon render, the app is automatically adding a stroke around fills that have stroke set to “none” width 0… Normally, not an issue, but I have a very detailed file, it makes things blurry…
Here’s an example of one:
I put it together in Affinity Designer, and it looks correct, but the detailed inverted lion engrave just turns into a mess… the thing is, it’s not a limitation of the glowforge itself because if I convert it to a raster image and engrave it, it can totally handle it.
Could someone maybe let me know what I’m doing wrong, or if this is a bug in the import/rendering process of svgs? Thanks!
When I open your SVG in Illustrator, this is what the lion graphic looks like:
I think what you are wanting is to have the grey area engraved, right? So what I did in Illustrator was to Ungroup, then Release Compound Path. I hid everything but the grey lion fills, selected them all, and changed the color to white (just to make it easier to see). Then I did a Show All (but re-hid the circular outline to get it out of my way). Selected the grey background part and sent it to the back. Selected the whole thing and did a Pathfinder…Minus Front. That gave me this:
Sorry, I don’t know how to do that in Affinity Designer. Basically, you need to punch the image out of the background. Instead, the GFUI was attempting to score all those outline pieces in the lion design.
Oh man, that’s crazy… it doesn’t look that way at all in Affinity, but that makes sense. Thanks! I’ll see if I can figure out what Affinity is doing strangely… this is what the original looks like to me in Affinity:
Thanks for taking a look at it… If anyone more familiar with Affinity has any idea of what horrible thing I did to make it look correct but export so terribly, suggestions are welcome! I am still very very new to Affinity.
Yes, you need help from an Affinity person for sure. But one thing to keep in mind is that layered designs like the above (white fills layered on a gray fill), are not going to work the way you expect them to. You need to be able to see that background grid through the white pieces.
Wooah… okay, now I understand even less… So I changed the fill mode from “Alternate (Even-Odd)” to “Winding (Non-Zero)” and now I see what you were seeing… But release compound path isn’t even available to me, since Affinity thinks it’s just a single curve.
Oh, yeah for sure. It’s not super clear in the screenshot I posted, but in Affinity that isn’t a white fill on top of a grey fill… Affinity thinks it’s empty based on the Even-odd fill mode (the default in Affinity). It’s only when I switch to the winding fill mode that it thinks the whole thing is filled in like in the screenshot you posted.
Using the original file here’s what I see (with red rectangle beneath the design for clarity):
Alternate (Even-Odd) :
It’s a question of fill rules. In that file it’s set to use the even-odd winding rule, but I think the Glowforge always uses the non-zero rule. I’ve run into this a few times, but I never got around to making a good example to send to support.
If I toggle the fill rule in Affinity Designer you can see it switch to show it the same way the Glowforge does:
Some of the other paths in the file use the nonzero rule, so those explicitly set the style on the <path> element to override the style from the root <svg> element:
<path d="M644.083,590.93C643.917,591.041 643.667,591.097 643.333,591.097C643,591.097… path data clipped for brevity …655,590.652 654.833,590.93Z" style="fill-rule:nonzero;"/>
Whereas the path in question doesn’t set the fill-rule explicitly so it should be using the fill-rule inherited from the root <svg> element.
As far as I can tell the Glowforge completely ignores the “fill-rule” setting and always applies the nonzero winding rule. I tried modifying the <path> to set it explicitly and the Glowforge still ignored it. I’m sending a test file to support.
Oh, and I just figured out why I run into this so often. When you use the Geometry->Subtract operation in AD, the resulting path always seems to use the even-odd rule. Given that’s the normal way to “punch out” one path from another shape, it comes up a lot.
This whole thing is way over my head and the discussion may be well beyond the info in this linked post, but thought I’d share it just in case. (The first half of the thread was us just trying to figure out what was going on lol.)
Wow, thank you so much for the info! Just knowing that glowforge always uses the non-zero fill mode will make it easier to double check images before uploading.
Thank you all for your comments and help, it’s awesome having a community like this to help troubleshoot! You’re all amazing.
