I’ve put in proofgrade material, doublechecked power settings, the mirror is in great shape, and the lens (while it does have a small scratch, and there’s a second on the way) seems fine.
The Glowforge had been sitting untouched for a while, over a year, and this is the first time I’ve tried to cut with it since then. Ideas? I’m stumped for what to test next.
In the 20 or so tests I’ve done with custom and proofgrade settings, NONE of them have made any difference to whether the laser turns on. The head moves, the laser does not turn on and no mark is made on the paper.
Do you see any light/plasma action in the tube when it’s supposed to be cutting? That will help decipher if the tube is working and if you have something wrong in the optical path somewhere.
Well my glowforge is also not firing the laser. it started this last sunday but i just now got time to look at it today. I went thru all the checks and still it doesnt work. Maybe we can get a response from them at some point.
Mike
Hi and welcome to the forum @gmikewilliams and @mark.chandler. This section, Problems & Support, is where you make a post if you need help with your machine from Glowforge’s staff. Posting here opens a support ticket with them. However, commenting on someone else’s ticket won’t create a ticket for you and won’t get you help with your machine. You need to make a post of your own, or email support@glowforge.com, or use the live support chat during business hours.
really? its also for the owners to discuss problems and support them as a group.
You make tickets at support@glowforge. its alot faster. I guess mark and i were making the statement that alan is not the only one with this problem.
I’m sorry if I was unclear. You said that you were having a problem with your machine and wanted a response from the staff. To get that response, you’ll need your own ticket, whether you open it by email or by posting in this forum on your own. I just wanted you to know that you won’t get help with your machine by commenting in others’ tickets. You’re free to do so for any other reason of course.
Still no luck with the laser, after several cleanings, shut down / restarts, and checking the cables that I can see / access, the tube never lights up, the head moves as if its cutting, but no actual progress.
