I focused this in the center when I cut. This took an hour to cut.
It started at the top left and worked its way right across the top, then went down, and worked its way to the left. The top started off good, but when it went back to put the diamonds and the center hole, the alignment was off. But then it corrected itself at the end with the bottom left snowflakes. When it cut the top right snowflakes 1/3 way through the alignment was off, then it seems it self corrected, then threw the alignment off again, then self corrected…
I have cleaned the tray, cleaned all the lens, and cameras.
There is no debris.
Material is flat.
Nothing bumped the head.
Always cleaned and moved the head when it was off.
I have restarted several times over the past few days.
This is the third sheet it has messed up.
I deleted the original file and re-uploaded the file.
I have cut this file before with no problems.
Here is the file: Snowflake-1.zip (26.1 KB)
Actually it might be the file, and I’ll tell you why.
You have an inordinate amount of data in it…that is a lot of vector shapes, and you have filled shapes instead of unfilled Stroke lines…but you intend it to be cut.
The GF interface can convert fills to cuts, but the possibility of introducing error for something that packed is pretty high.
Try this one instead and just see if it works….(not sure it will, it’s a test).
I got rid of the fill and turned on the strokes, then broke it up into three sections. What I would suggest is cutting that one section at a time by setting the alternate sections to ignore.
I have printed this file and three more like it no problem before. It does convert it to strokes. I’ll try breaking up the file tomorrow. Thanks Jules!
Using inkscape, and digging a little deeper, I am seeing some very strange behavior, where the entire middle row, and the first large snowflake (from the left) on the top and bottom rows do not edit the way they should. For example, I can’t change fill/stroke on them individually, only when grouped with everything else. I also can’t get into the node editor for any of those, but the others are all fine.
The same is true for the version Jules shared as well.
I’ve reloaded Inkscape without change. I’m on a Mac.
I did create the file. All the snowflakes are copies just resized differently. I created it in inkscape. I see what you mean by being able to edit some of the nodes on snowflakes, but not being able to select the nodes on some of the others. Very strange. I can’t ungroup or break it apart or anything…
Like I said before it cut fine originally. Went back to my glowforge library to cut again and it messed up. It would be strange if inkscape self corrupted, but even more strange if the the file self corrupted from glowforge’s library.
Yeah, I used the step and repeat when creating them. I cannot say for certain if the other files cut the same exact way. I guess I should trouble shoot with some paper to see if it is the file or the glowforge misbehaving.
I did the copy/paste thing and created this, with cut steps broken out like Jules did, but breaking it out a little more. The colors match GF default print order, so top 4 big, middle 5, bottom 4, then the smaller stuff. Snowflake-1.svg.zip (41.8 KB)
I can’t guarantee it’s going to work, but it’s not behaving “funky” like your original or Jules modified files on my system.
The node count is around 11,000. We had a member cut a file with 39,000 nodes recently so I don’t think that’s an issue.
That’s going to need support to look at the resulting data that is sent down to the machine. It’s not a mechanical issue because it’s not carrying across multiple elements.
To get the node count in Inkscape, you just use the node edit tool, double click one object, then select all. It will show the number of nodes in the status bar.
No. It doesn’t use the lid camera (which is what the alignment process adjusts) for anything while working on a print. Just for initial head centering on power-up, then for material placement before you hit print.
There’s something going on with the translation of the file from upload to print.
