does anyone have a work around for gluing to clear adhesive and not having it look like garbage?
I made a miniature desk and the top is frosted and the glue shows through and looks so bad.
A picture of what you’re making might help folks to offer better suggestions. Is it possible to use double-sided tape? If the issue is that the glue is messy, you can trim tape to be neater and just cover the areas you need to stick.
If gluing them together doesn’t work out well for you, you could try using wood on the edges (like a frame) - it’s a workaround I have tried before (but it’s been a while so I don’t have any specific examples to show you on hand).
