Has anyone had success cutting the gold mirrored acrylic from Inventables? After much testing I’ve found that cutting works best using black acrylic proof grade as the material setting, and cutting from the back.
HOWEVER, it seems to overheat the foil that is used for the mirror, creating vapor channels that ruin the project. Any ideas?
Hi there, I’ve cut the mirrored acrylic (Not from inventables) selecting (Clear Acrylic) Proofgrade settings and cutting the design from the back. Didn’t have any problem with it! (Pro Machine)
I’ve also cut their mirrored, from the back, but I removed the plastic & replaced it with the 6” low tack masking tape. Pretty sure I also used black PF setting. Now I buy my mirrored locally, don’t re-mask, cut from the top and use orange PG setting for gold & yellow PG setting for silver,
I cut a lot of the mirrored gold and silver acrylic. I don’t mask the back, I cut from the back and use med clear acrylic setting. Works great most of the time. I am having issues with my machine lately but it’s not because of the acrylic.
Have you ever tried the acrylic from Canal Plastics Center? Their sheets come in 12x18" and works out to be a little less per square inch than inventibles.
If someone shares a print that they’ve made, please respect their sharing and do not ask for the source design or artwork. Designs take work and have value, and when you ask someone to give you that value for free, you undermine their work.
I constantly cut gold mirrored acrylic and I use the Clear Acrylic settings. the GF cut the acrylic perfectly with this settings. I cut it from the back (don’t remove the plastic from the shiny part).
I find that a speed of 140 and 85 power generally works well for me.
I take the plastic masking off as it can melt and leave behind little balls of goo on the acrylic. You can put paper masking on both sides if you want to be really careful, but I usually just do the back (non-mirrored) side. And mirrored acrylic is extruded and not cast so it’s really going to stink when you cut it. Good luck!
What vendor do you use for your Mirror Acrylic. I tried JP Plastics and it worked great but it is $10 more per sheet than Inventables…a little nervous to try cheaper priced product. Any insight? Will be cutting large single letters. Pretty new to GF! Thanks!
Genevieve
Both Johnson plastics and Inventables are reputable suppliers. Assuming your supplier is actually selling you acrylic, the main difference between acrylics is cast vs. extruded. You want cast. That is another thing to watch for, people selling extruded as cast (they may not know.) Johnson plastics and Inventables know the difference and should mark them correctly. For ebay or 3rd party Amazon sellers, I’d read the comments and see if other laser users have posted anything.
