As far as I can tell it is safe to laser, but I can’t yet figure out if it looks good. No point in getting an expensive material if it isn’t going to look better than basswood after carving.
Due to the nature of laser engraving, the quest for a material that is low in texture after engraving may be futile anyway I guess…
Semi-off topic I see a lot of mention of fire danger in many materials. And I was wondering if a layer of absorbent paper spritzed with water might prevent the flare ups. It would take extra pews as the laser would have to evaporate the water at the cut but that which was nearby would retard any further burning?
The reason I say maybe is that the flareups I’ve seen (mostly with corrugated cardboard, some with BB – hey, maybe it’s a repeated-initial thing) seem to happen when heat and flammable gases build up somewhere inside the material being zapped. So a cooling layer at the surface might not help.
As it seems nearly everyone wants to use cardboard as a quick infinite resource to try stuff anyway I was planning to have a spray bottle for just such experimenting. We know the material will burn where it is cut, the effort would be to keep the whole mess from bursting unto flames. And a handy spritzer would help stop a fire that did start.
As for the specifics here closed cell foam it would not have the volume of open space to build up unburnt gasses
this was on Coastal Enterprise Precision Board (I called them to make sure it would be safe to put in the laser, they said ‘yes… but most people use mechanical engraving techniques with it, so let us know how it turns out’)
My mom used to be a kindergarten and preschool teacher, and in some of her schools they sprayed products like no-burn on the curtains in the classroom. Its basically a fire retardant spray that you can apply on fabric, unfinished wood, paper, pretty much anything that’s a little porous. It leaves, like, a thin film on whatever you spray it on. Its supposedly water based and nontoxic, but I dont know if it would be laser safe. I remember one teacher saying it was just water and baking soda (which does seem possible with the film it leaves), but I dont know if that is true.
Plus side would be you could spray your material lightly and let it totally dry before lasing - so you wouldn’t need to put wet stuff in the glowforge. I’m also pretty sure you could just brush off the residue it leaves with a little effort after everything is cut. Downside, I have no idea if its laser safe and its more expensive than water.
