@fugee13 - Iāve put up a little tutorial on the process in Illustrator - here:
Thanks so much for posting this
No prob!
Adobe illustrator looks a little different on my screen so I am unable to follow these steps. Not sure what i am doing wrong. ![]()
Welcome to the forum.
What looks different? How far did you get in this example before things looked different?
I already have an SVG that looks like this - not matter what I do I cannot get to the same outcome as you⦠any ideas?
Canāt you delete one of the lines in node editing mode?
If dimensional accuracy is not critical this is definitely how I would do it.
The latest version of Illustrator still does the Center Line Trace. There is a preset (Line Art) that will get you close to where you want to be. But it only works on bitmaps.
Iām so glad this was resurrected. Can I ask if anyone has the issue of it just going white when they do a trace? I even created a big fat lined bitmap just to try the line art thing. No matter what I do, no matter how thick the lines are, it goes white. In either instance.
(I donāt actually have a ālive traceā. I have Image trace, and Live paint, and neither look like the example above. I did find the Line Art in presets, but it goes white too.) ā¦ETA: Could the lines be too thick? I tried to do something that looked like a coloring book, and not like a line drawing. lol, Iām seriously lost.
I have to say that I know absolutely ZERO about illustrator. I can do photoshop with my eyes closed, so I understand the basics of adobe, but Iām absolutely clueless about this.
If anyone has even an inkling of an idea, Iād appreciate it so much.
Thanks in advance!
You guys, I spent all day trying to figure this out, and I wanted to share what I found. Resolution makes all the difference! I have no idea why, but lowering the resolution from 300 to 72 finally made it work! (Iām not kidding when I say I ran image trace at least 500 times today. I had to figure this out.) So following @Jules instructions (thought line art might work too) and lowering the resolution gave me darn near perfect centerline. Thanks so much for this tread and sending me down a rabbit hole where a learned a ton!
Which version of AI are you using? (Live trace has been around for several versions)
āImage traceā replaced it around CS6, I just learned that today. Weāre on the subscription so all I know is that weāre up to date. ![]()
I think I learned enough today that I might start using it more. I never thought I would!
Hey Robin! Any chance you could screen record your process? I tried lowing the resolution and Iām still coming up blank, would love to see exactly what youāre doing!
Omg thank you. I import svg tracings from illustrator all the time and the double path made fusion sad
