I'm looking for a very slippery laser-safe plastic
I am trying to figure out a good way to engrave a detailed design on special sticker material, then pick up that design with transfer paper and move it to another item. To do this I need to engrave the sticker sheet on some kind of substrate that will tolerate some laser energy, and that is very slippery so the sticker will peel off.
I can kind of do this by using a slab of pebbled HDPE (like a cutting board) as the backing. It shrugs off the laser energy that makes it through the engraving. It’s also pretty slippery.
However, it is not possible to transfer bits of the design if they are too small. They simply stick to the HDPE more than they do to the transfer paper.
Here’s an example… You can see that about half the fine details got left behind. But this is close, so close to working well!
I tried silicone sheet. It seemed very promising. But, the power that makes it to the silicone produces a TON of ash and that interferes with the transfer.
It MAY be possible to find a lower power setting that will work without this problem, but the masking material I am using produces the best image when you aren’t too stingy with power. I’ll keep playing with this but it may not work out.
I can also try a high-tack transfer paper. But, if it’s too high, then I will have a problem transferring the tiny bits of the design onto the target glass item.
So really, the ideal solution is some kind of laser-resistant slippery slab that will easily release the sticker material to low tack transfer paper.
If you have any ideas for a material like that, please let me know!
If it were me, and the sticker sheet I was trying to cut already came with a backing… I’d try to glue that backing down onto a solid substrate, something like MDF or Baltic birch.
If you’re worried about smoke from that substrate, then just glue it straight to a steel plate. In theory, you would be able to cut as hard as he wanted and the backing for the sticker would be firmly affixed to the substrate so that your transfer tape could pick up the bits.
It all depends on having a backing material that can adhere to the surface. You know that the sticker will release from default backing, you just need to be sure that your backing is firmly attached to your bb/steel.
Unfortunately the sticker material doesn’t come with backing, it is on a roll.
I do have non-stick paper backing for other kinds of stickers, like vinyl sheet. And I thought about using that, but I have not been able to engrave this sticker material in such a way that a piece of paper behind it won’t get torched. And, the backing has to hold together or the little islands in the engraved design will blow away.
But, there’s no reason not to try that with a metal backing, maybe it’ll work better than I am imagining. I can just sacrifice some sticker vinyl for the backing.
Teflon or Delrin?
If you’re thinking of trying metal, what about glass? That’s cheap enough, and you can get scraps from the hardware store to test with.
If you’re really nailing the backing with the laser the glass will be affected and eventually spall. A simple steel sheet from Home Depot is cheap, magnetic, and will shrug off the laser with no effect.
Thin plastics generally don’t require much energy to cut, so I’d expect a glass sheet to shrug it off. But adhesives generally stick great to glass and if I understand the OP’s goal, that’d be a problem.
They do make laserable material with adhesive backings for just this purpose. No intermediate transfer step required. I have a few rolls in different colors.
This stuff:
Yeah bare steel and glass will hold on to the material I want to transfer too tightly. The sticker material is actually a glass etching mask and it sticks to glass like crazy.
In normal use, you put the mask on and engrave away the unwanted parts, like with that Laser Foil. Then, you sandblast. But that way you are limited to items that fit into the machine, and that have a flat surface.
I’m working on this transfer process because I want the benefits of a highly detailed mask (with no weeding) on larger and curved items, like beer mugs.
Original thread with lazermask settings:
Followup thread where I started the transfer method:
It’s a promising technique but a more forgiving backing board would make it much much better.
It would probably not stick to cooking paper. What does hold comes right off like normal backing paper. The texture created by rabbit skin glue can be amazing as well.
Here’s a sample pic of what I am trying to accomplish. This is a large wine glass and it is masked with LazerMask engraved on my HDPE slab. Even if this glass fit in the Glowforge the curvature would make engraving this large design into the LazerMask impossible.
I used medium-tack paper transfer tape to move the design over to the glass. It worked sorta OK, but the little triangle in the capital “A” could not be picked up by the paper until I un-stuck it from the HDPE with the point of a craft knife. It was pretty fussy.
If the transfer technique can be perfected, allowing smaller bits to be picked up easily, it would make much more intricate designs possible. This would be far superior to a vinyl sticker mask made on a drag knife cutter, which not only has limited resolution, but weeding vinyl sucks.
(You may notice some wrinkles in the mask. This design is big enough that I was pushing my luck with the compound curvature of the wine glass… But LazerMask is flexible enough that it worked out. If a wrinkle touched the edge of a letter I could still smooth it down. That’s another way it is superior to vinyl stickers.)
Delrin is a possibility for sure and I am trying to find a scrap.
Teflon… Well, that is why I posted another thread on “why do some laser outfits say teflon is safe, and others say never to cut it?” Outside of this project, I find the discrepancy irritating! :slight_smile:
I cut Delrin all the time. 3mm sheet cuts great. I have some 1.5mm (which is probably more like what you want if you need to bend it around a curved surface) but it wasn’t as easy to cut. Got too melty too easily. I gave it a few shots and shelved it for later.
If I recall, it produces Formaldehyde when it burns. Good ventilation is important.
I’m not looking to cut it, it would be used as a backing for cutting another material that I then need to peel off.
I have been looking at all the various things I have here, not for laser, just in-general. One that I wonder about is the cheap plastic/poly binders you get - someone here posted about cutting and/or engraving on them, and I believe it worked out. With the low power settings needed to cut thru your masking, that may not mark the surface of the plastic-like material.
They are $1 at Wally, you could almost consider them single-use if it works out.
Good idea, thanks. I wonder what kind of plastic that is?
I am sure they vary, but I am guessing polypropylene. I have some nice sheets but they can not be used on the GF in the thickness I have, but thin sheets can be cut according to some. Think overhead transparency material, but the binders are thicker.
Ah. I don’t think it’ll work very well. The plastic’s melting point isn’t very high. Even low laser power will probably remove some material. And having watched my cutter cutting Delrin, what I’ve seen is that it liquifies much faster than it burns off, so after the cut is complete you can see “streaks” where liquid plastic has been pushed and then resolidified, in lines running forward and away from the cut, because of the breeze created by the air assist fan.
Thanks for those observations, that helps.
It cuts, but it leaves a melty edge. That’s okay for some uses but I use it more for creating faux-bearings where I glue them to some other material and then the material slides more easily than if it were raw wood.
Was just a thought, worth testing.
