Would be interested in understanding how as the bitmap of the image you posted shows a pretty good outline, in fact the SVG based design you uploaded didn’t keep proportion around the bell.
Can you post the SVG with the embedded bitmap? What’s posted on the forum comes in only as a jpg.
You can post SVGs with no problem. Just upload it. The problem is not in the uploading, but in how Discourse displays them. Look at the markup of the file. The display values for Height and Width assume pixels and not inches. Just add two zeros after each.
Yeah, it might have something to do with how the file was saved from Illustrator, because when I opened yours directly in the interface, it comes out with the clarinet shrunk.
Is there is something funky with bitmap? I did a trace in Inkscape and it elongated the whole vector outline of the clarinet. That’s interesting.
Best result might be to get a good PNG of the clarinet and remove the background, then trace that outline. Not quite sure how I would process that bitmap of the clarinet to have a good engraved image and not just a blur. So much black. So little highlight.
Tom - I decided “how hard could it be” and then started playing with your image for the last 45 minutes. I’ve attached a file that has your version and one I redrew because… I’m stubborn.
The magic appears to be that I took the clarinet.JPG and made it a PNG file and that weird scaling thing went away. I’ve attached the file. You will probably want to go with a higher res PNG, and you can make it with a transparent background and place it in AI too.
I make stupid mistakes but I didn’t make this one.
It does. What the heck!
I did, thanks.
Definitely interesting. The bitmap is just a high-res jpeg I found. I didn’t trace it. I just pasted it onto my artboard. The vector cut of it WAS actually a trace. I’d taken the clarinet in Photoshop, outlined it smoothed the outline, and then brought that into Illustrator and traced it, giving me a cutting outline of the clarinet (with a nice contoured border).
I rebooted. Opened up the file. Saved it again. Opened it in the GFUI. PERFECT NOW.
I dunno… I’ve had Illustrator open for days. Maybe something just got hung up in it somewhere.
