Hi Glowforgers, long time since I’ve posted, but I’m fretting over something that just appeared when I try to import a new design to my forge…For some reason the attached is ‘inverting’ the curves on the outline in this .svg. I’ve uploaded older versions of this file before with no issues, but now it’s apparently choking on this one and I have no idea why as I haven’t changed anything with regards to software…any ideas? TIA.
So I downloaded your file and opened it in Inkscape, but the outside line doesn’t show in inkscape. When I export the file from the Glowforge interface and open it in Inkscape, the corners of the outside are concave. I am not slick enough with Inkscape to know what is going on. face plate v5-1.svg.zip (13.2 KB)
This was giving me fits so I played around with it. Something weird with how you defined the curves for the feet seems to break up the path, but if you paste into a plain SVG, it imports into the GF UI without issue.
What version of inskape are you using? I have 1.0.2. When I download it and open it directly then I see the messed up corners but when I import it into a new inskape file it shows up fine. I saved the corrected version as v6 and pasted it below and it imports fine now into the app.
That’s interesting…could you append the file? The curves come from using QCAD offset function and all prior versions of this were perfectly fine, so I’m at a loss as to what changed…I’m using Inkscape V1.02 on a Mac.
Append it how? Append the v5 file you had originally posted? Does the v6 file work for you?
Either way, I do think based on the comments from everyone else this sounds like its not a glowforge problem. We can still go into what might be the problem, because it sounds interesting, but you might want to move the thread to the “everything else” space or the “beyond the manual” space.
Apologies…yep, just did that and opened it in Inkscape and the glow forge page and all is good! Many many thanks…still stumped as to what I did wrong, but I will try and trace my steps…
(rx ry x-axis-rotation large-arc-flag sweep-flag x y)+
Draws an elliptical arc from the current point to ( x , y ). The size and orientation of the ellipse are defined by two radii ( rx , ry ) and an x-axis-rotation , which indicates how the ellipse as a whole is rotated, in degrees, relative to the current coordinate system. The center ( cx , cy ) of the ellipse is calculated automatically to satisfy the constraints imposed by the other parameters. large-arc-flag and sweep-flag contribute to the automatic calculations and help determine how the arc is drawn.
If sweep-flag is ‘1’, then the arc will be drawn in a “positive-angle” direction (i.e., the ellipse formula x= cx + rx *cos(theta) and y= cy + ry *sin(theta) is evaluated such that theta starts at an angle corresponding to the current point and increases positively until the arc reaches (x,y)). A value of 0 causes the arc to be drawn in a “negative-angle” direction (i.e., theta starts at an angle value corresponding to the current point and decreases until the arc reaches (x,y)).
This is what the code looks like:
For further details, this is the code for my test SVG:
<path xmlns="http://www.w3.org/2000/svg" d="M 0,0 v 3 a 3,-3 0 0 0 3,3 h 10
a 3,-3 0 0 0 3,-3 v -3 z"
style="stroke:#ff0000;stroke-width:0.25" id="path1010"/>
<path xmlns="http://www.w3.org/2000/svg" d="M0,10 v 3 a 3,-3 0 0 1 3,3 h 10
a 3,-3 0 0 1 3,-3 v -3 z"
style="stroke:#0000ff;stroke-width:0.25" id="path1010"/>
But when opening the original file (v5) directly it shows the error of the edges in Inkscape and Adobe. V5 file was not from GFUI but was having the issues when imported into GFUI and the issues were the same when opening up the file directly. It was only when importing the file into Inkscape (I use windows and maybe that made the difference) that it resolved it. I have Inkscape on my Mac but just didn’t power it up to test that.
I don’t see how that can be a GFUI bug unless v5 was downloaded from GFUI (which it’s missing the settings information if it was).
This reminds me of the whole “what color do you see the dress as” thing.
I have a lot of different design software. I just right clicked on the original post image and saved it as a different name to my desk top and then had my computer open the file with affinity and below is what AI shows. @jestelle , The file did not pass through the GFUI at all :
