Nope, this is exactly the place to talk process
Youâll fit right in, welcome!
Thatâs it! We had some offers to clear our trees
âLet me get rid of that million-dollar forest for youââŚâI won"t charge you a dime!â ![]()
definitely interested!! How about USPS Priority shipping. If it fits in the box, it ships at one low rate!
Aloha Aaron. There are a few different methods for doing Abalone inlays, but at the risk of revealing our secrets, allow me to introduce you to the easiest by far; engrave the area you want the abalone to inlay into, making the engraved area just a hair bigger than the abalone piece. Then laser cut the abalone to match. Then peel off the adhesive backing very carefully and apply abalone to wood while heating abalone with a heat gun. https://www.mudhole.com/MicroFlex-Abalone-Shell-Inlays?gclid=Cj0KCQjw7ZL6BRCmARIsAH6XFDKnS3I6Vy5hFM7KDGHaicKpyZ0-zKP9hEpyc6AAZ8i29ApWTTpC510aAsoiEALw_wcB
Thanks. So it must be artificial abalone. In Vcarve you do something similar but with angled cuts - female and male which is not possible with a laser cutter.
I would like some of that wood. How do I get some of that wood?
Is there a reason that a laser would not burn through real abalone? It neatly cuts through everything else.
Abalone shells, like most others, are essentially rock, composed of calcium carbonate.
Iâve never worked with them but would never have assumed they can be cut on a GFâŚ
It is super thin stuff
Come to think of it, someone has posted designs with it - earrings I think?
I remember looking it up on AmazonâŚ
It was @amandarogers808
Successful crafting business in Hawaii
I bought some at the time. Just didnât try it yet.
That was it!
If I knew anyone with pierced ears, I might have tried it myself!
The product is real Paua shell, just micro thin and adhered to an adhesive backing sheet.
Koa is lovely wood. I am interested too!
I love Koa!
Aloha Dan! Weâve done some really wonderful stuff with our Glowforge and some Hawaiian Koa wood. If you like, weâd be happy to send a couple of pieces to GF for you guys to play with.
YES! Sounds fabulous.
So the Glowforge is creating a pocket and you adhere it to that?
Actually you can. The laser is not cutting a perfectly perpendicular slice through the material. Thicker material will show the slant more than thin (try mating 2 pieces of acrylic together at a right angle and youâll see right away). But this is often used to good effect for inlays - flipping the inlay over puts the widest part on top which makes for tight fitting inlay joints. Lots of posts about using the technique here including some from @evansd2 and other inlay gurus. ![]()
I call it âflip matingâ, if you want to search more specifically.
