It shows as"LID OPEN" when it actually closed as usuall
Since you’ve opened another ticket, you can use it to run a few tests that support will probably ask for… they will see your answers here and not need to wait for you to run them…
This sounds like it might be a lid cable issue, so you need to run through all of the tests listed below to eliminate other causes. Post the results of the tests here so support can see that you have run them.
