I’m a new owner, and wanting to make sure I get this right I paid close attention to the manual about cleaning. When I read you need to do a cleaning every 40hrs of use I thought what is the best way to track time run? After giving it some thought and consideration I decided to make up a rough Excel spread sheet. The spread sheet keeps growing but initially it started as a record of when I used the machine and how long the project took to print, the record included a running tally rounded to 15min increments and a logic formula giving 1 of two outputs either “OK” or “Clean”. This, I thought was great.
As I began looking into cutting other than Proofgrade material it lead me to manual mode and the importance of records for the setting so I am working on incorporating that into the spread sheet as well.
Just thought I’d post this, it may mean nothing to most but may be an inspiration to others.
