I just clicked on a link attached to the story about Laser Foil, the story was about Kiss Cutting, will the Glowforge be able to do this? http://52lasers.com/2015/08/19/85-sticker-sheets/ I wonder about this because they are manually setting power and speed to achieve these cuts, will we have close to this control?
We should be able to. Have not yet heard than we actually can.
I arrived here thinking I’d see an led lit cutout of the band.
This is interesting too.
Can someone explain why we wouldn’t be able to do this? Why wouldn’t we be able to adjust the power and speed settings? Or is there something more that I’m missing?
No you can definitely adjust them. (seen it in action - Marion’s machine)
Kiss cutting is delicate. You need to cut through the decal itself without cutting into the backing (or carrier sheet) at all.
Not deep enough and the decal will tear or not come away at all.
If you cut too deep the backing will peel up along with the decal. This can be annoying on a personal project or it can be disastrous for a commercial one. Deeper still and you will cut all the way through.
Decal material will vary in thickness. Dialing the glowforge in to cut through just the decal material and not the carrier sheet should be possible, but we have not seen it yet.
Of course, this is what cutting plotters do all day long. I can’t speak for the hobby cutters, but the pro-grade machines do it quite well… as long as you have a sharp blade and your settings are dialed in correctly for the material (which often includes a very small test cut or series of test cuts).
Plus i remember @dan posting how to set the power and speed settings manually not too long ago. Unfortunately i wasn’t able to find the post when i just looked.
The simple answer is yes, it should.
The longer answer is test and dial in your settings for a given material. The Glowforge will come with presets for proofgrade materials, which the GF team tests. But, from what we have seen, full manual controls are available in the manual cutting section which will be power, speed in inches per minute (I believe is what Marion has been posting) and resolution.
It all depends on your materials for the stickers. I engraved something today and did some test squares. The lightest of the tests vaporized the masking material almost perfectly and left a layer of adhesive with just the slightest discoloration below.
I just have the standard Avery labels in my office. I don’t have any big sheets. What do folks use to do this method on lasers?
Unfortunately, I don’t know, heh. I don’t have a laser. My main concern, which you and others have answered is whether or not we could manually alter the speed and power ourselves, which now I understand we can. That is great, like I said while I don’t know what settings people currently use on other machines to “kiss cut” I think, like you said depending upon the material, we will be able to do this ourselves.
When @marmak3261 records his sessions, the interface changes quickly, but there are power adjustments.
Biggest plus to the ProofGrade material, it automatically does the settings for the end user.
Well there is another question for Glowforge, will there be any Sticker/Adhesive sheets or Laminate offered in Proofgrade materials?
It was at about the 32:30 where the settings show up (power and speed).
You will need to have the YouTube displayed in full screen.
Veneers, yes…not sure if that’s what you meant by laminates. @marmak3261 displayed the contents of the Proofgrade pack on his unboxing videos.
No stickers or paper products that I can recall.
Not quite decals, but the ‘wooden stickers’ they were giving out at MakerFaire were sweet, and I hope that material is available as Proofgrade. Don’t know what they were calling it, but it had a 3m adhesive on the back.
edit: this one. I hadn’t looked closely at it for a while. It is a “self-adhesive veneer” product of some kind.
@smcgathyfay as usual has done it…
Thank you for sharing your experiences and letting us know whats possible.
- Rich
Sorry, I meant Window Cling Vinyls, though not sure if that is safe to cut. I also meant not neccesarily the Proofgrade materials they send us, but available in their store.
Pretty sure the vinyl is a no go …don’t know about the store stuff so @dan would need to answer the stickers/papers question.
But if you are planning to do a lot of them, a laser isn’t really the right tool for the job. For that you want a cheap digital cutter (Silhouette) because those are designed to do just exactly that, and do it very reliably, with perfect 3-Point alignment and an optical eye.
And those can handle vinyl films.
