Hi All,
I recently had the dreaded non stop centring glitch rear its ugly head and im at a loss, its happened before but this time its really bad.
I’ve tried everything i’ve been able to read including power cycling both my machine and internet router, have cleaned the lenses and camera and checked all 5 of the lid LED strip connectors which are fine and still no luck.
I have tried moving the head manually to the centre with the machine off, turning it on and waiting for 15/20 minutes then closing the lid. This creates even more issues because once the lid is closed after this waiting period it will start to calibrate/centre, however it just calibrates/centres as if the wide angle camera isnt working at all and the head “centres” straight into the front wall of the machine and the belt starts skipping on the wheels as the cutting head gets driven into the front door of the cutting bed.
If i try this process without manually moving the head to the centre of the machine and leave it at the normal starting position (top left), open the lid and turn it on and wait 15 - 20 mins then close the lid it will calibrate/centre, but then it will slowly but surely (in slow diagonal stop starts) calibrate its way down towards the bottom right and start driving itself into the front door of the cutting bed again.
Its almost as if the machine is trying to calibrate/centre the head blindly like the camera itself isnt working to locate the glow forge symbol at all.
