Proofgrade is stained and finished, so shouldn’t be a problem with most stains & paints on any laserable material. Go for it.
Based on input from @dan, this was bad advice. Be sure to test all paints and stains to make sure they are laser safe. That being said, there are many owners who have successfully lasered prefinished materials, both PG and non-PG.
I used something similar and it worked pretty well. As @jbv said, your masking might not stick as well, though I’ve found that if I let the wood dry for several days the masking sticks as well as before it was stained. I’ve also found that I need to increase power and/or reduce speed on engraves for finished wood, though I imagine that mainly depends on the stain you’re using.
I haven’t tried polyurethane yet. I’ve been using lacquer, but I’ve only used it after engraving and cutting. It seems as though you could engrave after using lacquer, though, based on this thread:
@smcgathyfay responded first in that thread — I’m sure she knows a lot more about this than I do.
Laser safety of materials belongs in Beyond the Manual, so I’m moving it there.
This is wrong. We had to work hard to find a laser-compatible finish coat (and it’s an unusual process); you should assume that all materials are not laser compatible unless the manufacturer tells you otherwise.
It would be great to see laser-safe finishes available in the store. You are obviously not going to offer an infinite matrix of material with all possible finish options.
