Leather USB keeper keychain
Made to accompany these:
svg and zip:
For personal use only as per forum rules!
leather%20keychain%20usb
leather keychain usb.svg.zip (250.9 KB)
I used a relatively thin scrap leather. Use the Set focus feature if you’re not sure. It’s a tight fit, so if you’re using thicker leather you may have to tweak the file and make the pattern wider.
I used 6mm rivets for the sides and an 8mm rivet at the top.
https://smile.amazon.com/dp/B07F71FXYT/ref=cm_sw_em_r_mt_dp_U_Spf5Cb1S6KD01
Related to this post:
Cute little holster! :wink:
Thanks for the file.
Thanks for sharing! This inspires me for something similar. I’ll share if I ever get my act together to design it!
Of course mine had to be no-sew… :wink:
You could come up with a sewn one!
I’ve got patterns for sewn versions, but I really like the rivets. I’ve seen a lot of sewn hand sanitizer holders, though, so I was thinking of seeing if I could make one with a similar vibe to yours! But maybe with cork…
That sounds cool! Love to see it if and when you get to that point.
Thanks for sharing
Gosh, thanks for your design and all the info and links needed to make it!
