I’m thinking the reason my initial calibration didn’t work exactly perfectly was because there was some warpage in the sheet of draftboard. Is it OK to tape the edges down, or does the camera need to see the exactly square edges of the draftboard in order for this to work?
yes, you need the board to be as flat as possible.
even better than tape, use some of your scrap 1/8" material and make some of these hold-down pins to put around the edges of the board.
My cable arrived and was fitted Thursday, that got me back up and running ( THANK YOU )
I did a couple of quick test cut/engraves to make sure everything was as it should be and then carried out the calibration. Made a big difference, not perfect still a little off on the RHS but better than previous. THANK YOU AGAIN!
For the record, pretty sure you mean “The Candy Man” because “the Candyman” is something so much less pleasant…
Really? (No doubt a movie I haven’t seen.)
I was thinking of the one in the song from Willy Wonka. (Sorry @dan.)
I’m not sure I’ve seen it either, but it’s definitely a slasher horror movie…
Okay, yeah, that definitely was not the Candy Man i was referring to.
Perhaps it is an age thing but I am remembering the novel made movie about a rich southern girl brought low. I was thinking it was Faulkner as it is his style but in any case not a compliment.
No, I wasn’t referring to that kind of Candy Man either.
(For pity’s sake!)
Considering the addictive nature of making stuff on the Glowforge the distance might not be so much. ![]()
I have been trying to run the new calibration, but have been unsuccessful. Attached is the error message I keep receiving.
I have tried:
- Turning unit on/off
- Resetting router
- Turned off all devices connected to wifi
- 2 different proofgrade medium draftboards front/back
- Removed/cleaned the crumb tray
- Cleaned the machine to make sure it closed correctly
- Cleaned cameras and lenses
I’ve definitely heard it used this way, as well, although I think the book might be a slightly more obscure reference.
And I agree that it might be the most appropriate reference of all.
I’m pretty pleased with the recalibration. I think this was a brilliant decision to jump on this asap.
There’s a camera for focusing on the bottom of the head; have you cleaned that one too? I think that solved this problem for one person.
Yes, I removed/cleaned the lens and also the mirror on the top of the head under the logo plate.
And the two small round windows on the bottom of the head? (Just checking. Most people miss those.)
Like @Jules said – the one on the BOTTOM of the head.
They’re not talking about the one that you remove from the head. There are two small circles to the left and right of the larger hole where the main lens goes in. The two on the sides are flush to the bottom surface of the head. Those need to be cleaned too.
