@takitus It’s our pleasure
I can’t speak to fan control - that’s squarely in another department. But I’m excited for it too…
@jkopel we’re working on it!
Well, if you’re running paper that’s out of spec for your print device… too thick, too big…
Yeah. Custom inkless business cards
How are people getting around interference from the air assist with these light materials?
Magnets and/or tape.
In addition to magnets and tap as @Tom_A describes, you can also do what I do with the ultralight fabric I cut for work, in splitting your cut order to leave tiny tabs attached until the last moment as it cuts.
That is awesome! Out of curiosity, what does it look like back lit? I think that’s what I’d like to use it for.
Good thinkin!
Have you seen Moo business cards on Luxe stock? They have a colour sandwiched in the middle. Could totally etch the white top layer off and reveal the mid layer for those as you suggest.
With low power mode it will be interesting to see what people come up with. I’ve liked this image ever since I first started Googling laser cutting ideas.
Oh, damn! trots off to get a leaf…
Do you have the Glowforge cut the tabs/bridges at the end of the work order? Or did you manually detach? My thinnest gasket material is thicker (~0.01") than 20# copy paper (~0.004") and would definitely be affected by the air assist.
Here was my original proof of concept cut test (the green are the last tabs to go)
https://community.glowforge.com/t/space-invaders-or-mitral-valve-leaflets-you-decide/7331
Amazing. I had seen your different iterations of the valve simulator, but hadn’t seen that topic of you actually cutting out the mesh. Thank you for patiently pointing me back to it.
Oh man that is cool. Bookmarked that for sure
But I can get detail definition and combine engrave & cuts with precise alignment this way (assuming the brown toasting of the paper is a good color for your design). It’ll be handy for card work.
What I think will be really useful will be a combination of laser cutting and scoring paper over a preprinted image. Pepakura is a prime example, or a combination of laser etching over a single color stamp for a card. It would be a cool combination of old school and new technology. I think that will be nice.
One thing I’m curious about is how weak the etched paper becomes? Is it more brittle in that area or thinner?
