Can someone help me determine a good baseline for cutting some Luan?
The luan is about .16" Thick.
What would be a good baseline settings for cutting?
What would be a good baseline setting for score / engraving etc?
Thanks!
Thanks!
Try searching for Meranti settings too.
You’d find this, among others:
That being said, you’ll be better off with testing than just trying someone else’s settings.
I did a lot with Luan plywood, and the surface layer is thinner than paint and what is beneath looks really bad. I therefore either cut or scored all that I did,
As this is not about showing off what you have made and is discussing non-pg settings and materials it needs to be in the Beyond the Manual section. I can put it there for you,
Thanks for sharing this. It’s super helpful as I’m super new to this.
