I’m having a hell of a time getting a perfect square cut.
I’ve done the squaring tutorial in the help section, but is there anything I can tweak on the machine so I can avoid having to do it every time I start up? Even after I square it, it seems better, but not great.
Here’s pics of a freshly cleaned and started machine cutting a 20mm square (no squaring done):
It’s so tiny that you could see how oblong some things can get if I cut bigger things.
Can I loosen or tighten some bolts somewhere to get the gantry square on startup?
