Same issue I reported Here
The only file I have run today 4/19, 2-hour print and the laser pauses multiple times toward the end of the operation. Most of the run time is engraving 77 tokens and hasn’t yet paused during engraving, so far the pauses have all happened during the cuts.
Sometimes it would resume and complete 4-5 cuts and pause again. After pushing the button sometimes it would immediately pause again, and I instantly pushed the button again. Sitting there, I had to hit the button 8 times to resume and finish the print. The only message the UI had was the same one you see when you intentionally pause, no error messages.
I’m worried about my machine, could someone please look at the logs and help me understand this?
Thanks!
The GFUI crashed right after this screen. I restarted the design and the print was still listed as going. That’s when I thought to press the hardware print button again.
I could come up with a theory… I haven’t read all of your posts on the subject, specifically to see how far into each project it is… but, they started zipping the motion plans. One would presume that only X-amount can fit into the current buffer, and then the next one has to be unzipped and the current one removed from storage.
Not a great theory, but makes sense in a way that it would pause momentarily, but, you would think it would auto-resume.
Okay, here’s a really off the wall suggestion. Have you removed and inspected the head to see if a magnet is possibly stuck there? I had one jump up once (long before the new fan messages) and was looking all over for it.
The engrave on the first side of this file is almost 2 hours, no problem. the cuts cause it apparently. I flipped the tokens and completed the other long engrave without a hitch.
Just finished the print (3:40 PM mountain) and it paused 17 times out of 77 cuts. Random frequency, it might do 20 cuts and pause, and pause again after 2-3 cuts. Occasionally it will pause almost immediately after I push the button.
