Make a Name Pendant in Affinity Designer
#1
Okay this is just a quickie in response to a question about how to do it…the customer wanted to create a name pendant in Affinity Designer:
  1. Open the software and select your font, type out the name:
  1. Select everything, right click and Convert to Curves.
  2. Select everything, right click and Ungroup. Resize or shift the letters over so that they overlap at some point.
  1. Select everything, right click, Geometry >Add.
  1. Set the fill color to Null and give it a stroke color.
  1. If you want to add a small hanging ring, draw up a couple of circles, centered, and combine it with the name shape using the Add function again:
That’s about it! :slightly_smiling_face:
Cut out names
#2
Nice writeup, Jules! I was going to try to eventually get around to learning how to do this with Adobe Illustrator. But I keep hearing good things about Affinity Designer, so I may have to check it out! Looks like it’s only $35 in the Mac store.
#3
Just an aside…a faster way to make the hanging ring is to use the donut shape. Just make sure the center part is the size you want it and …ADD it
#4
I’ve been using Affinity since pretty much day one. I tried others…Inkscape, plus a couple more. Just didn’t seem that user friendly, so bought Affinity. I paid $50 for it, which was still a bargain…plus, there are no subscription fees. I recommend it highly.
#5
I’m just bored enough today that I might write that up. (Not hard, same process, just different places where the tools are hidden.) :smile:
#6
Jules what is the settings you use when you open the new project
#7
I use the geometry/Boolean stuff from up above in the contextual menu (is that the right term?)…that menu bar across the top…rather than the drop downs.
#8
You’ve been using AD longer than I have…I only bought it to test Snapmarks on when I got onto that Beta. :smile:
#9
Settings look like this:
#10
Oh yeah…:slightly_smiling_face: I remember that now.
#11
great info, thanks - gives me a push to really learn AD. I use an old version of Illustrator (CS6 - pre cc) and I’m pretty sure one of these Mac OS updates is going to kill it forever, so this is much appreciated.
#12
I use CS5. (Hey if it ain’t broke, don’t fix it!) :smile:
#13
Cheers to the old days when we bought software, hahaha.
#14
Nice! I am on CS6 and plan on staying. I just can’t justify spending $250 a year right now for it. I suppose if I start making a steady income off the GF each month I might decide to upgrade to the cloud.
#15
Haven’t seen a darn thing in the CC that I can’t do in CS5, so you can bet i won’t be subscribing. (Mine’s not quite as fancy, but who the heck cares?) :smile:
#16
I’ll probably do the same. As long as I can do what I need to, no point in upgrading. I’ve noticed that lately, I get alerts saying “would you like to downgrade this design” because I am buying designs that are done in a newer version.
#17
have you run into anything that doesn’t actually open though? I haven’t yet… knock on wood…
#18
Thank you again Jules
#19
My pleasure! :slightly_smiling_face:
#20
Jules what is the Font name the you use
