Marquetry inlay
Hi! i would like to learn veneer inlay/marquetry, any advice on how to start?
If you input “inlay” into search you will be rewarded with lots of information and experience.
Did you have a particular project in mind?
Here are some cool projects someone shared from their first attempts at inlay. (They are cool, too!)
Maybe that will help get you started. But I easily found these just by searching “inlay” in the search bar, so you can probably find TONS of helpful info that can get you going in whatever direction you like!
I have experimented several times with various approaches. Almost all designs have a part that is connected and a part that is disconnected. If I have two thicknesses, then I engrave the disconnected part in the thicker material, and cut out the connected part in the thinner material. This makes it easier to fit everything.
If it is marquetry, there is a need to keep the designs simple to make it easier to fit.
