Maximum Cut Size Less Than 11"?
Nope. It’s only less than 19" if you are doing an engrave. If you are doing a simple cut then the usable design space is currently at least 10.95" X 19.45". I went through a dozen different rectangle designs to come up with those numbers and the maximum is likely just a hair larger but I got bored trying to find it.
