Birch ply , inner ring made of stacks of rings aligned via an aluminum wire, outside made from parametric curved surface. Has issues with aligning and making the “gear’s teeth” to be in step with the curve.
For now filled with leftover copper wire rings. Searching for better weights. It is now at about 500g.
That’s the prettiest weight I’ve ever seen. I like how you shaped the fingers on the vertical join so they wouldn’t come apart, too.
You should go ahead and post the files in the Free Files section, if you’re willing to share them. I can’t think of a use for it at the moment, but it’s a useful enough shape that someone is sure to want it sooner or later!
If you’re looking for heavier - over on the low-temperature metal casting thread I got hooked up with “lead free fishing weights”. They melt at about 300(150) degrees and are about 2x2x1/2 (50x50x12) per pound(450g) - so you could get that mic stand up to easily 3-4lb (1350-1800g) of weight!
I just got a bunch of their metal and I’m pleased with it. Do check their website to compare though as they add $10 a bar to the same product they list on Amazon.
