Mini Fireplace Design
Back
Separator
Acrylic
Separator
Front
Fireplace _V6
Fireplace _V6.zip (672.1 KB)
*I’ve added the zip above so you can get the raster image. It went from a flat black/grey image to the depth it has using the “matte jelly” filter in Inkscape - I then took a screenshot of the depth image, posted that back into the raster program, then copied that back into Inkscape. (The dance is because the GFUI doesn’t recognize vector shading) then using Edit > Make a Bitmap Copy before uploading to the :glowforge: because the GFUI doesn’t recognize vector shading
There is some variation in depth in 1/8" materials, so worth measuring the depth of your main piece before cutting the hole in the base
SD Graphic Engrave
Medium basswood ply Cut/Score
Put together with Elmer’s glue, and then dry brushed with white/grey/black acrylic paint
I added some paint touches to the orange acrylic, which I should have done before glueing it together!
Cute, cute, cute! Thanks so much! Is a 3D engrave of the bricks a part of your design? I’m trying to figure out how you did it.
Wooh! totally cool!
Unfortunately not included. I was curious to see the file and to try that, because I’ve never had 3D engraves come out so “clean”…
Oh darn. I forget that Discourse deletes the raster. I’ll upload a zip with it in there!
You make the coolest stuff. Thanks for sharing!
We need something stronger than “like”… I am in awe of this…
@eflyguy @cynd11 the .zip file is there now with my raster for the 3D engrave
This is perfect! I might just have to make one for my dollhouse loving friend!
Love this! (As I am making notes on how to use this for gingerbread next year :rofl:)
Do have a question though, I am not familiar with the filter you mentioned in Inkscape, so I am going to look into that to see what it does. But you mentioned the screenshot and loading into the raster program to copy back into Inkscape. Couldn’t you have exported that as PNG and loaded it back in without going through the step of putting in the raster? It’s similar to what I did for my stone chimney, although I did mine a bit differently since I didn’t know how to get a vector shading. I just used blur in gimp and then inverted the colors.
Possibly - but I knew the screen shot method would work so I went with it! I did try exporting to the raster program and it came it as flat grey, so I presumed anything done via the vector program would be wiped…worth testing though!
It’s a big big for dollhouse - but if everything was done with 1/8 it would be half the width, so the size could be reduced at least that much!
Yes, I realize that I’m going to have to pull apart your design a little bit and adapt… if you don’t mind! It reminds me of the fireplace I created inside a match box once - using card stock and water color.
this is something I have never tried before… Including the painting to look so real. If only there was a video… Thanks for the parents. maybe I will acquire an artistic friend in the near future.
Absolutely feel free to modify the design in any way that makes your heart happy :slight_smile:
The technique is called dry brushing - and on something that’s already three dimensional it’s shockingly easy - and as a bonus, if you don’t like what you did you can always laser another one! This video has a nice overview. I tend to use a much smaller brush (1/4" wide or so), and dump less paint on the paper towel, but this is pretty similar
I used a mix of white/black/grey - and didn’t mix them smoothly which got a random mix of those colours. The other option is to do each colour individually starting with the darkest.
That is cool…
Thank you so very much.
so cute! thank you!
So cute! Thanks for sharing!
