Moisture in machine. Camera not found. Lid coming apart in the right corner
HELP!! The lid of my GF is coming apart and most recently the lid was covered in moisture. Now it says the camera is not found. I have tried to reach out to the GF support, but did not get any answers. Anyone else have this problem? Would much appreciate the help. Pics attached.
Lots of people have had this issue, a quick search can show you all the advice they got.
https://community.glowforge.com/search?q=lid%20detached%20in:first
Good luck, support can take a while to get back to you – but they do a good job once they do.
I believe that the moisture and the lid coming loose may be two different problems in that the lid coming off did not cause the moisture. Do you vent outdoors and do you disconnect the hose when the machine is not in use?
As for the lid coming off, consult the link in the previous post.
Thanks for the prompt response!
I vent outdoors and do not disconnect when not in use. Do you think that is the reason for the moisture?!! I do live in Florida, so it does get hot. Thanks a ton for the prompt response!
Do you have any sort of backflow preventer?
I live in GA, which is plenty humid… but I have a louvered vent cover that prevents air from coming back in. I never have moisture problems in 5-ish years of use.
Previously in louvered vents:
Absolutely. Many others have found condensation in there machines when they didn’t have a blast gate or remove the vent from the window overnight. Glowforge recommends disconnecting when not in use. The solution is to make sure everything gets dried out. Open the lid and circulate air for a couple of days. It won’t solve the lid problem, but might resolve the camera not found which may be caused by wet electronics.
Unplug the GF while it’s drying out.
Thank you all for your insightful replies. The lid issue was solved effectively with the JB Weld epoxy.
If you’ve got hot moist air outside, and a cold dry air conditioned room inside, as soon as that outside air comes down your ventilation hose into the Glowforge, it’ll condense into moisture inside. I forgot to close my blast gate once and it was dripping wet inside the next day.
