Everything you need to know about Inkscape and Glowforge in 10 (whooops 25) minutes.
I couldn’t get it to fit 10 minutes and there are a couple of things I missed out. But this covers 95% of inkscape things I use every day in building GF projects. No waffle.
Errata: 3,4 and 5 are zoom selected, drawing, page NOT F5
and Ctrl-Alt-H, Ctrl-Alt-T to centre, NOT Ctrl-H, Ctrl-T
Also, I apologise for the sound wandering out of sync, no idea how to fix that!
Thanks for doing this! I didn’t watch the whole thing as I’m an Illustrator user primarily, but I think this should be useful for lots of Inkscape users.
This is great, thank you so much for doing the video.
It’s really hard to see any detail, can you tell me when you created the top to the box what numbers you used to make the inside measurements slightly larger?
So in this case the first time for the bottom, the OUTSIDE measurements are 200 x 50.
My material is 3mm thick, so for the top, the INSIDE measurements should be 200 x 50, but I added 1mm.
However, you might need a bit more if for example your box lid is very deep, because I suspect the vacuum pressure when you lift a deep lid off can be quite high. It also depends on the lid shape, can you get a good grip on it.
I’ve got no rule and so far everytime I have had to tweak whatever my first guess was because it was too loose or too tight, or tight one way but not the other etc.
I thought youtube transcoded it into a bunch of resolutions automatically? When you click on the gear, do you get other options? I see 720P as the highest resolution, which is fairly legible…
Not ideal, but not terrible either. I bet google knows how to push it further. Maybe an upload setting?
I’m going to try a new upload at 1728x1080 - which is my original capture.
I might also try a 1080p upload as well. Maybe YT doesn’t like non-standard resolutions.
