I received my Glowforge today and I am in the process of setting it up.
When I first turned the unit on I got a teal light and it showed up on my WiFi I could not connect to the unit so after several attempts I powered the unit down and restarted it. The light is now orange and the unit will will not show up on my WiFi. Please let me know if anyone has any ideas on how to troubleshoot this issue.
I have sent this to support but I thought it would be worth posting here as well.
I’m still a little unsure of the correct order of things, but you might try holding down the yellow button until it turns blue. (About ten seconds.) Then turn off the machine for 1 minute and try again. (That reboots it and restarts the setup routine.)
What I’ve seen from others here is that if you can make sure the signal to the GF from the Wifi source is really strong for that first setup connection, it seems to be more successful. Like, temporarily move the wifi source closer to the GF if possible.
