I posted this on made with the glowforge but now want to share the plans.
Here is the zip:
Dollhouse.zip (24.0 KB)
Enjoy
Here is the zip:
Enjoy
Wow. Thanks!
Oh, that’s fantastic! Thanks for sharing it!
(Are you back in production now?)
Very generous of you to share! Thanks!
The lens was shipped from TX waiting in MA
Oh, love this! Thanks so much for sharing!
Wow that is really nice! I might have to cut one out for my daughter. Thanks for the share!
Beautiful, thanks for sharing. What thickness material did you use for the cut file/design?
Thank you for your generosity!
Thank You! It’s wonderful, now I need more Granddaughters
Proof Grade Medium Basswood Plywood
Very generous of you to share! Nice design.
Thank you so very much for the file. I have a question. Last night I used medium draft board for the house. Were the shingles supposed to be cut out individually? Mine were cut out separately.
It looks to me like he shingles on the original were scored.
My file shows also them scored but they cut through the PG draft wood
I suggest you double-check your settings. PG DB score is only power setting 6 (vs. Full power for cut, on a Pro), which would take 10-15 passes (or more) to cut thru.
(these are PG settings, I just “opened” them to show the actual numbers)
Thank you so very much!!! I really appreciate your time to help me. I just got my Glowforge Pro in September and everyday I am learning.
No the shingles were a different color and were to be scored.
Yes the shingles are scored, I have made this file out of 1/8" Baltic Birch and medium proof grade plywoods mixing the walls and floors for contrast. I did not add the stairs in the file because I forgot to make them here is the file for them:
This is giving me trouble here is the zip file with stairs:
Dollhouse.zip (25.8 KB)
This is going to be so fun to make with my granddaughter. Thank you!
