You could use a tablet and do all the design work on your main computer. We have an iPad we can use just to run the app and design on a laptop. Everything is kept organized on dropbox
Storage for materials, storage for partially processed materials, waste baskets or boxes to hold offcuts that you just can’t seem to let go of, storage for projects.
A computer that you can use for design while you are doing long prints. You will want to be comfortable and busy while you wait.
and a place for tools and other things you’ll need.
Ridgid and Titan tools both have these stand/supports for outfeed on a table saw that would probably work well for the pass-through. A battery backup system will negate the need for a surge protector.
Interesting. So, you do surge protector into the wall and then battery backup into the surge protector and then everything else into the battery backup?
Interesting in a data center you would see this? as normally the battery rooms are isolated several lays back from the grid and things like flywheel energy storage are in front to take the small bumps before battery’s are switches to and generator spin up
Then again maybe your are talking about small fata centers where everything has small ups and not the small I am talking about where you essentially have a ups power plant?
Not in a data center. You’d have Feeder to UPS to PDU (multiple feed) to Load. But for what I’m doing at home, it’s an option until I get a Tesla Powerwall (someday). I’d rather a little more redundancy than less. Besides, with the protector, I can also plug in other stuff if I have need but it doesn’t need to be on the UPS (like a sander). I mounted the box on a joist in the basement, and this way I can just run the protector’s cord along the ceiling (I have hooks I can drape the cord in) to other parts of the basement when I’m not plugged into the UPS.
I hate flywheels, btw. And I’ve only been in one place with both flywheels and batteries, most places are batteries (switch to on static transfer) to generators (automatic transfer switch). Never on battery long, but the UPS handles the inverter/rectifier part.
We’re moving into a house built in the '50s having had several remodels along the way.
We are upgrading the electrical system including a modern service panel. The electrician recommended adding a whole-house surge suppressor to the panel. Incremental cost is only $85, but it would cost a couple hours labor if that’s all they were doing.
Articles still recommend additional surge protection on particularly susceptible equipment to protect against surges generated on the same circuit and low level surges that get by the main suppressor.
