@Jules, this and the matrix are fantastic resources.
Do you realize, though, that most people have no idea that those exist, or where they are?
I’ve been here for a while, and I just managed to track them down a couple weeks ago. And, honestly, it’s a little bewildering when you see that mass of links.
Crowd sourced docs are great and all, but people really need some actual manufacturer provided documentation.
The fact that there is great debate about how the current features even work is a testament to that.
I don’t really disagree with you (except the part where I’m smart – I’d have to cite a lack of evidence), but the point I was making is that the Glowforge isn’t a design tool and can’t be expected to know what you meant instead of what you said. There are a lot of applications that can create SVGs and each one will behave differently. I certainly don’t expect Glowforge to include a “how to” for every one of those applications. In my case I didn’t know how to use any of them, so I didn’t have any preconceived notions that I knew what the hell I was doing. If I was an Inkscape expert and my SVG didn’t work properly on the Glowforge, it’s possible I might assume the Glowforge was at fault. At the same time, however, there’s plenty of evidence (namely, all of the projects that people are posting) that the Glowforge isn’t a piece of junk that can’t even read a SVG properly. Hopefully at that point I’d just ask if anyone else was having a problem similar to mine.
Edited to add: I agree with you that it would be great if there were more documentation, though. There was a thread a day or so ago where Dan listed a couple of keyboard shortcuts that I never knew about. Something like that really should be documented on the website.
Yeah, I know. I try to point people towards them when I can. (If you guys would do the same, it would help a lot of beginners to get past that initial OMG! hump that happens.)
Glowforge was too busy building a machine to do those kinds of tutorials on design. They don’t have the resources for it, and it has to do mainly with learning to use outside design software, so that is something that people pretty much need to pick up on their own. A bunch of us volunteered to put that together to help people get started in doing their own designs.
Unless you’re buying a design that someone else has already created (catalog) then everyone needs to learn a few basic design concepts if they want to do anything past engraving on objects using visual placement, or tracing a drawing with the interface. That’s all the functionality that we’re going to get with the laser. (Maybe a few more bells and whistles later, but it’s just so much easier, and more accurate, to do the designing and aligning in something that was made for doing design work.)
An alternative could be to recognize common problems with the SVGs when they are uploaded. I’m not wise in the ways of SVG inner workings, but can’t the GUI detect that the SVG is not "responsive " and direct the user to some general guidelines about properly prepping an SVG? (I fully realize I may have just completely changed the direction of this topic).
We can add a tutorial or listing of specific keystroke commands to the tutorials area…honestly, I was holding off on doing one until I saw if they included it in the manual. (Wasn’t going to tread on their toes any more than I already do, KWIM?)
There are easy shortcuts and functionality that a lot of beginners won’t stumble across for a while, and they are always adding new goodies…I’ll see what I can put together.
Totally agree with you here and the seeds are there if they will grow. Right now we see that for elements that they cannot work through like text that has not been converted into curves.
I thought about adding a comment like that to my post. The problem with that, in my opinion, is that it makes Glowforge responsible for keeping up with the idiosyncrasies of third-party software. It’s possible you could limit that to just Illustrator (since it’s the market leader), but as soon as Adobe adds a new feature that “breaks” a SVG on the Glowforge (like the “responsive” option), everyone will be up in arms that Glowforge didn’t catch it. In this particular case, I suppose the app could give an error message that the height and width of the SVG isn’t set, but I still think in the end they would end up having to support applications other than their own. A lot of people would think that since Glowforge knows there’s a problem, they should be able to tell them how to fix it.
A simple click two spots and tell me the distance between them function would work wonders. It wont tell you 0.010 resizing but it will show you if its 1/4" out
Hey folks… To be honest I’m not concerned about the SVG file printing off scale. That was my first test and it is obviously in the file. The second attempt was with a PDF of the same file. That worked perfectly so I at least have cut capability which is the main thing for me at the moment.
I guess my frustration was ill timed due to quite a few people experience some issues with calibration and the GF going off line for no reason. Just so happens I was setting up for the first time when these issues had happened to others. So I can live with that.
Today was definitely better than yesterday. To me the app seems more like an Alpha than a Beta. I tried an engrave and could not find how to cut the perimeter after the engrave. That should have been obvious? I then wanted to cut in a certain order like inside to outside so that the center parts do not get out of alignment. Every other laser provides a choice to select line color for queuing the cut and or engrave. I’m sure that I saw that somewhere but I could not find it? It would probably help new users if more features are on the Main control page instead of another that other page where you load files. Its just not that obvious in the beginning. Just simple stuff arranged better would make this App so much easier to navigate and understand what is happening.
One thing that I did find was that using an iPad is near to useless for moving the part to cut around the screen for placement… I tried a mini and a full size and finally gave up and had to use my Mac in another room.
I’m not sure what Adobe Max is supposed to be after viewing the movie. I certainly hope that I don’t have to get a copy of Adobe. Or is it an App that is being developed for GF instead of GF Company having to do one.
As for not being able to engrave text…Wow!. All my files have descriptive placement and part numbering on them. My normal order of cutting on other lasers is engrave text, cut oder via color denoting scoring, sequential cutting order and power levels for each. Without these minimal requirements then I’m screwed regards my business.
It would also be nice if I use my own materials that once I have them cutting correctly that I could save off my own material files. I must be honest that the proof grade quality is nice but is around ten times the cost of the same or similar materials that I source locally.
People generally take the path of least resistance (my own theory, not peer reviewed). The easy path is getting frustrated when something doesn’t “just work”.
If they get valuable feedback, like helpful error messages, they can be gently trained to use that something and the result is a positive user experience.
If they have the to run the gauntlet of an Internet forum to get support, well…
Personally, I think the Problems and Support topics shouldn’t have people like me posting on them. I’m not helpful.
I’m going to put something together that will help with those issues tomorrow. There are shortcuts and drag and drop that you can use to order your operations, but it’s not something that has been accumulated into one place yet. Up until now, people have just asked and someone told them how to do it.
So come back tomorrow (evening). It will take me that long to organize it into something coherent, and i’ll leave it open for other people to add to it, so it will become a Wiki.
I quite often use my own material, I just pick the closet proofgrade material and use that as a starting point. Once you select a proofgrade material just switch to manual settings and take note of those numbers and just adjust them from there.
Absolutely agree. One of my biggest griefs with the interface is the lack of helpful error messages. “Something went wrong” is useless.
I disagree. Totally my opinion here, but my feeling is that a decent percentage (at a wild guess I’d say 30-40%) of the tickets opened in Problems and Support are actually fixed by non-staff members. That’s because we all run into these common issues like the responsive option in AI and know what to do to fix them. I’m a completely newb with vector programs, but even I can point out solutions to the most common problems because I’ve seen it pop up time and time again. When it comes to solving problems, never overlook the power of the hive mind.
