Ribbon catching on bolt head during print
#1
Posting this here instead of Problems and Suport because I’m not really sure if it is a problem…
I’ve noticed that the ribbon comes into contact with a screw/bolt head as it goes back and forth.
Anyone else seeing the same thing? Just pull it gently forward?
#2
Video isn’t showing but definitely move this to problems and support, or send them an email.
#3
I think I remember someone saying that moving a thread to Problems & Support doesn’t notify staff the same way opening a new thread there does. But I could be misremebering.
#4
No. You are correct.
#5
Yup, that’s why I didn’t move it for them. I should have noted that @jed_ike needs to post a new thread there. Thanks :slight_smile:
#6
I’ll send an email instead of moving it. Don’t want to double up their queue.
#7
On mine about a third of the ribbon cable is glued directly to the gantry surface. This is so the ribbon will track correctly as it folds during the left/right movement of the head. My ribbon has a good bit of distance between it and that screw. Two possibilities: either the ribbon is glued slightly askew or the glue has let go.
Ribbon cable catching on bolt head
#8
Thanks @rpegg! That makes sense. I’ll check how/if the ribbon on mine is glued down.
closed #9
