Roly Poly Bowly
First off, my thanks to @davidaspitzer and @marmak3261 for sharing the details for doing this. This is a process I was intrigued to try out… called a slump bowl…….which is actually quite ugly sounding. I made a circle design and used Glowria to cut it out of 1/4” thick glass-green acrylic. Centered it over the upturned bottom of a ceramic coffee mug without a handle, then set it on a cookie sheet, put it into the preheated grill on our deck… at about 300-325 and let it be for about 30 min, checking in on it every 10 min. After 30 min, I inverted a small stainless steel bowl over it and very slowly and carefully pushed it down to make the sides fold downward. I left that bowl on it until it was cooled off.
It’s about 4.25” across. Not flat on the bottom because of the bowl I used to put over the top to form it. There are some imperfections, but I think it turned out really cute and fun. It’s deformed in several places, so I will call it a 'deformation rocker bowl’ or maybe a ‘roly poly bowly’ instead of a slump bowl. So, while it is imperfect, it points to other possibilities.
It’s cute!
Very nice!
Roly poly makes a good lampshade perhaps? Or a ring to sit on ? Many cool places to go.
Fabulous! I too am intrigued by this. I’d say nice first attempt!
I like how it looks - the thick glass green acrylic is such a good choice for this. I am intrigued with the pedestal it is sitting on in the first photo.
I love this bowl done in the green-glass acrylic! It really does look like glass.
I’m just sad that the rest of the forum doesn’t get to see it.
Oh wow! Thought that was glass too! It looks fantastic! (And I never thought to slump 1/4"…it looks much more stable as a bowl.) :sunglasses::+1:
I love this so much - wow the 1/4" is gorgeous!
It’s this; Another edge lit
Perhaps a lamp shade…but this little one is too tiny. Good idea, though
The thickness of your acrylic really makes it look special. I like the color of the acrylic too. :heart_eyes:
That shape and the movement in the bowl are very pleasing as is the color of the acrylic. Nice work.
I don’t know how I missed that post (or forgot it) That is really a great piece.
If you haven’t taken the time to go through all of @Xabbess’s topics, it would be well worth it. She has been key to a lot of technical solutions with design, software, gfui and materials.
Too bad they are hidden from most under the VIP section.
Look at this girl. You really needed that laser! I love your creativity, great choice of material.
Nice Work. :sunglasses:
This is lovely. I also agree about the glass green acrylic… now I really want some.
You definitely should share it in the wild (i.e. “Made on a GF”)
OK…my guru friends. A few people here think I should put this in a different category…not VIP. Should I move the entire post… double post it…or what?
I would just post again—we all understand and don’t mind seeing it twice. I’m glad you will do this, as I will be able to send folks to your project anytime slumping bowls or green glass acrylic comes up!
