shop
April 11, 2019, 3:37pm
6
there are plenty of examples of it actually doing them (engraving flasks) here if you search. i think it’s safe to say that if it fits and either has a coating you can engrave off or you use ceramark or the like, you can definitely do it.
[20180915_214646]
Ok, technically I just engraved away the paint, but these came out pretty nicely. I used the iPhone 7 material settings then adjusted the material height. Took 6 minutes at 700/100/270. Using vectors is great because crisp lines show up even at a “lower” dpi.
Here are the flasks in the picture
I had to remove the crumb tray and then prop these up on 2 sheets of scrap 1/8" material to get it to where the laser would be able to hit it well. There are 2 great tutorials in…
Saw where someone was messing with flasks last week and decided to try. Flask is powder coated stainless steel. I think I will try a polish to see if I can get the engrave to shine a little more.[image]
