The filter system is not very satisfactory for a couple of reasons - the main one being expense of replacing the filters. The filters can fill within hours if used for cutting mdf. Also, the filters have been out of stock for months. You are better off to change the exhaust system to have fewer bends and use an improved vent hose. I like this one:
The filter is crazy expensive, I cannot imagine using it.
An external fan and good leak-free ducting is the best answer. Let the fan run a while before you open the machine.
But you can never eliminate all the odor, the cut pieces smell a little. After they have sat in the machine a while with the external fan on, if I was super sensitive to smell, I would remove them to the garage or something like that and let them sit for another day or two.
But after cutting, the cut materials do smell. It just clings to them.
If you follow the conversation, instead of selectively quoting one part of my post, youâll note I was replying to comments about covering the machine while in operation, which is not necessary if the venting is working as intended.
I know, and I did follow the posts. I read her commenting that she is hyper sensitive to smells, regardless of where they come from. That is an important issue for her to consider. Tooling with the ventilation may not solve her problem. Her clean room idea may be a more practical solution. Same with the allowing the pieces to air in the garage.
I would stay away from owning a machine that burns stuff if I was overly sensitive to smells myself.
I had a problem with smoke and smells for over a year. I taped up the connections, I sealed the venting window seams, I covered the lid with towels, the works.
Finally, someone suggested that maybe I had a leak in the ductwork itself. I couldnât see any pinholes when I shined a light behind it and inside of it, but I wrapped the length of it in several layers of cling wrap, and ta-da! No more stink.
Except for extruded acrylic. My God, that stuff reeks for days. I eventually was given a choice between cutting mirrored acrylic or remaining married, so now I stick to wood and cast acrylic.
There is a lot of variabilities depending on the model of inline fan. they can move up to 800 cubic feet a minute (cfm) and while they would not reach that with a long exhaust, anything over 250 cfm going out the machine should do well. External fans are also much quieter than the exhaust fan on the machine. In any case, any holes up wind of the fan will have the air moving in, so only the hose from the fan to outside need be of concern.
The filters will do a good job as long as they are not clogged, but they clog amazingly fast, and the filter cost $250 to replace.
Are you using a vent with the self closing louvers? With the stock âinternalâ fan, it takes very little obstruction to cause back pressure in your air flow. Even a light breeze blowing towards that side of your house can disrupt the flow.
I an external exhaust fan a couple of years ago and it has changed the level of odor and smoke released into the room. Keep in mind, for best results the fan should be the last thing the air flows through on its way to being vented. If placed anywhere else along the hose you are creating positive pressure in that pathway that will seek anywhere to release the pressure (crack, pinhole, loose connection)
Hmmmm, mirrored acrylicâŚ
And I have never been able to eliminate the smell, despite over 4 years of trying. I canât figure out where itâs coming from.
My only point is âyour mileage may varyâ. Some folks have gotten it perfect, and others not so much.
We have a couple of these air quality monitors:
that we initially bought due to wildfires around California, and wanting to know what our local air quality was.
But I also found it really useful to diagnose, debug, and tweak various venting set ups.
I donât think it would detect all air contaminants, but it can definitely measure smoke from plywood.
If youâre still struggling something like this might help measure when, how, and where smoke is getting into your space.
One consideration â be sure the inline fan is at the exterior end of the run, so that it pulls exhaust through the hose rather than pushing. This keep the hose (along with its little holes and flaws) under negative pressure, just like the GF itself. Pushing creates positive pressure and will absolutely result in the stink youâre trying to avoid.
The forum has some excellent writeups on this â try searching for âexhaustâ and user @PrintToLaser using the forum search tool (magnifier at upper right).
Good luck!
Indeed! I also got an air quality monitor for my Glowforging area. One thing I found interesting about the resulting data: it did pick up on the time my tape had come loose and I was getting some smoke back into the room. Since I sealed it back up, I still smell some smoke during long cuts, but the air monitor doesnât register a significant change in particulates. I also canât see smoke anywhere, not even with my super-scientific method of turning the lights off and shining a laser pointer around.
I think this is because Iâm very sensitive to smoke and itâs at a low enough level to probably be unimportant in terms of health effects. It gives me a little peace of mind to see that the numbers are good even if itâs bothering my nose.
If at first you donât succeed get a bigger hammer!
Not always the best advice but I did find a really big hammer in terms of filtering smoke and smells. At one point I was having a problem with smoke and smells and Glowforge had not yet delivered the first filter so I got this.
It is definitely a bigger hammer clearing out most of the house without even having a hose to it (the link has them cheapest on Amazon)
And some people have a more sensitive sense of smell than others. I can smell my laser from elsewhere in the house. My husband canât smell it when heâs standing a few feet away.
One other thing to note is to be careful that other places in the home are not allowing the smoke to come in from outside. There have been many times someone left a window cracked that is near the room where the Glowforge is, and the smoke smell was coming BACK into the home. I try to check every time before I use it, but sometimes I forget. lol
So, taking a look at this pic, are you saying that the top part of the in-line fan should go straight outside without any additional hose? Looking to also decrease smell in the room. Thanks!!
Ideally yes. Even better mount the fan outside of you can.
As close as possible.
Just like the GF has gaps all around it but smoke doesnt(normally) come pouring out due to the fan pulling the air out the back, so too does physics work for the in-line fan. If there are holes or gaps in the line between the GF and the fan, the fan is pulling air into the hose so little smoke/smell should be escaping.
However, on the exit side of the fan, itâs being pushed instead. If there are holes(pin sized or smaller) or gaps in the joints, the smoke/smell will spill out of those. Even in minuscule amounts. You have a pretty short run so itâd be hard to make it much better.
How far does the hose extend outside?
Is that a sliding door that setup is sitting in?
Possibly is the hose dumping the smells into that area and itâs just seeping back in?
