Long time no see! 4+ years with no trouble to report?
How else would a remote tech support team work except by following a playbook, and identifying the likely cause of an issue by process of elimination, since they aren’t in your house and can’t directly examine the hardware?
That design flaw has been rectified since you bought your Glowforge. The current revision of the cable is longer at the bottom so that it doesn’t touch the hinge when the lid is fully extended.
Their fulfillment company only uses UPS and FedEx, since USPS generally doesn’t handle large and heavy packages affordably, which are the bulk of what Glowforge needs shipped. At commercial rates, it costs me $18 to ship a 1/2 pound bubble mailer by FedEx Home Delivery (their ground service) to the other side of the US. Add $2 for the packaging and labor and you’re at $20. If you add in some other things to your order, you can hit the free shipping threshold at $99.
@dan84 How does a 50 gram cable qualify as “large and heavy”? I would expect design flaws that cause failures to be fixed by GF. Not passed on to the consumer.
That is what the Warranty is about. I had no problem with the original black cable until I opened the lid too far just once. It is delicate so is shipped in a shipping tube to keep it from damage (and be very careful on install, the slightest touch with the sticky part will hold tighter than the force needed to damage the cable)
If one is ham handed they could go through a number of cables.
My existing cable has not failed yet, so I have not used it to verify it works, but I didn’t see any damage to it so hopeful it will work when installed.
I only ordered it because I had some other stuff I was ordering and since it was free shipping added it. I was scared to death they’d just toss it in the box with the seeing the disaster of shipments I’ve received before so was plenty thankful it shipped in its own box.
Thinking it’s only a big deal when a person thinks about it. Don’t know about y’all but if they had charged $50 with free shipping most wouldn’t complain. It’s a custom part so I was surprised the price was that only $19.
I think the crux of the matter here is that this is a well-known problem due to a design flaw in the early GF units. Why wouldn’t you (@dan ) address this proactively, rather than waiting for the issue to occur, then charging $40+ for a part, then having the customer apply the fix themselves? Even after receiving the part you are not out of the woods - Several folks have burned out the PCB when replacing the cable. Custom parts need custom expertise to ensure it is properly installed.
I ordered 2 last month and they came rolled up in a small box as described. They held up fine though. I still have never had one fail on me. I just had loaned out mine from my machines when they were out of stock. They still do well. But then again, I dont cut much on my machine and so it does not get the harsher environment.
This is just sad - Arrived finally after many delays and the cable is just in thrown there in a box with some air pack. Will try it out and see it it works…
