In honor of my happy Cake Day , I’m sharing this design. Months ago @bbum experimented with Mathematica to export SVGs of mandalas and I sorted through thousands of them to pick just one. Thanks, @bbum! Cleaned it up and deleted the outer parts to come up with a really nice result.
The mandala on the sides can either be set to cut or engrave; both give a nice result.
The cube only goes together if you stick to the diagram.
I line the bottom of the box with a little piece of felt.
The lid has an engrave on the top and on the inside. Run the print job first with the Curveball text step ignored; then, open the lid, carefully pry loose the lid without moving the sheet, and turn over and lay it back down. Set all steps to ignore, except for the Curveball text step and run.
That looks great. When I do 2-sided pieces I just open the lid and tape them down to the board then flip the whole thing over. I like your way better. LOL
Box itself is about 2"x2". Simple answer is no, you cannot resize it. If you know how to, you can, but basically you would have to redesign the whole thing from scratch taking into account different material thickness, etc.
