Greetings -
Decided to take another run at a table lamp following my previous ‘learning experience’ - The Table Lamp
This time I’ll simplify the design and use a different (cheaper) LED strip. So here we go -
I picked up this Honeywell 8.2 foot USB light strip as it was only $15, the width of the strip is less than .5", and the remote receiver is tiny and attached to the cord which can be housed ‘inside’ the lamp. The length and cut points to shorten it worked out perfectly as well, as you’ll see.
I won’t go into too much detail as this is the same style and construction technique as the last one, and I started with a cardboard sample to see how the LED strip would fit. I wanted it to shine in and out, so made a loop folded back on itself. The cut off mark happened to be in the perfect spot so I cut off about a foot to make it fit perfectly.
Made from numerous layers of one sheet each, I ended up using two medium black, three medium clear, one thick green glass, and one medium cherry. The cherry wasn’t necessary, I just wanted to add my logo to the back. If you don’t include the Cherry, total cost for the six layers, at current online sale price for PG, plus the LED strip totals $77.75
This is one of those projects where you have no idea what the final product is going to look like until you get all the pieces cut and assembled. So ya, burning $80 in materials with no idea how it’s going to look can be daunting. But I may have finally conquered my apprehension about this style of project, and have the confidence in my skill and vision to just go for it. ![]()
My vision for this piece was a sort of ‘Social Media Trophy’. Spoiler, I’m not a fan of it, in general, present company excepted.
So let’s put it all together and see what we got.
Here’s the finished back. I ran out of stainless acorn nuts so I’ll fix that after I get more. I wanted a ‘two sided’ lamp for this project, so I did cut outs for two of the images and extended the top thumb and hearts beyond the black face and back.
And now for the front, in different colors -
The little remote receiver works ‘through’ the layers of acrylic so you can still use it to turn on and off and change the colors. It’s tough to get a good picture and the multiple acrylic layers add that mirrored depth effect, which is totally cool. But hopefully this is enough to give you a good idea. This project completely meets my vision, and surpasses my expectation!
This last pic shows why I used thick green glass for the center section, the layer engraved with all the social media icons. The wording and poop are on separate layers, of clear, one behind and two in front of the green glass. This placed the green glass in the center of the LED strip, so it’s gets more light through it, making the logos a brighter and slightly different color.
Hope you enjoyed the write up,
HL
