I was struggling to get this 6"x5" silicone sand bucket to stay flat in the glowforge with using normal clips and so I decided to come up with a new solution.
It is really an open concept and anyone can build off it. I will go over my setup and all information you would need to do the same thing. I will also explain some of my design decisions to keep in mind if you want to make something along the same concept.
o if anyone wants to make this themself, here is the file and materials used to make it:
File (you have to right click on the image and select “save as” to save it as a svg):
You can make it with different slit spacing. The reason I picked mine was because of how I planned to have the webbing feed through sets of two slits and so I wanted to make sure there is a good size gap between those slits so that the gap does not break off easily.
Materials
- 12x20 medium draft board (you can use thicker if you want it to handle more tension)
- 1" Polypropylene Webbing (you can use nylon but nylon is really silky and I find it can loosen itself with the triglids)
- 1" triglid: Amazon.com
How I made the straps
- Cut the 1" webbing into 30" long pieces
- Use a lighter to burn end of the webbing and prevent it from unraveling (look on YouTube for how to do this if you are not familiar with it)
- Fed one end of the strap around the middle of a triglid and sewed it down (if you do not sew then rivets are a easy alternative)
Here is the result:
How I strap it down
The explanations might not make sense but the pictures show what I am meaning ![]()
Feed the webbing through a set of two slots and pull it through so that the sewed on triglid latches down
Slide a second triglid onto the webbing through the center of the triglid
Feed the end of the webbing through a set of slots and set your material on the board under the strap
Feed the end of the webbing through both triglids
Press down on your material and tighten the straps till its at the needed tension to keep the material flat
Bucket from tutorial
Here is the bucket I use in this example. I used settings that I found from searching in Beyond the Manual for silicone (non proof grade settings can only be shared there)
https://www.amazon.com/gp/product/B097GD94RR/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
