You know you were just waiting for the next puzzle from me
Fresh n’ tasty, this is a two-in-one, since there is puzzle band around the outside, and the center is a fit-placement of 14 hearts (you know, for Feb. 14th?). This puzzle is more difficult than the Halloween Leaf and my Christmas Tree puzzles!
Also includes an alternate piece that can be engraved on the back with your custom quote, hand-written note, or artwork.
It adds just a little bit of extra trickery! And makes it a family puzzle - let the kids do the outer ring, then the adults can figure out the center bit
I have several animal puzzle like the squirrel but I can’t figure out how to get it to cut right.
I used Inkscape and save as a svg file but it would only engrave. What am I doing wrong.
Thank you,
Pegkay53
Can you upload your .svg here (instead of the .jpeg above)? If you created it in Inkscape it could work - but if you imported a picture from elsewhere then likely what you need to do is Trace Bitmap. We’d be able to answer for sure if you upload your art.
Yeah, the forum strips rasters from within .svgs so that’s definitely what you’ve got. You can zip the .svg and post that here and it’ll remain intact.
Or open your art in Inkscape, click on it, then click on Path (in the menu bar), then Trace Bitmap.
See what that gets you.
